dave
Hello,
Could somebody please give me a hint on what to do about the ERC
analysis in Protel99SE giving me "floating input" errors in ALL my
input pins connected to a BUS. For example, a memomory address bus
connected to the address pins in the part, they all give me this
error. I have the "Electrical grid" enabled, and I have redrawn the
wire from the bus tap to the pin over and over, I see the "bubble" for
the electrical grid. I can move the part with the mouse (and pressing
CTRL key), and all the wires move with the part, which makes me think
that all wires are correctly connected to the pins.
I also have the "snap grid" enabled, and so the connection between
the bus tap and the pin is a straight line.
The part in the library has the right "Electrical type" setting for
all the pins. Address pins are "input," Data lines are "I/O," Control
lines are "Input," and VCC and GND are all "power." I tried updating
the part from the library, and also updating the part from the cache
in the schematic.
Any idea, hint or comment is appreciated.
Thanks in advance
David
in the schematic.
Thanks in advance
David
