I'm trying to build an LED flasher (as small as possible -- operating
on a 9V battery) like this...
http://www.ownthenight.com/html/Products/Illuminators/illphoenix.html
Here's how it works...
You attach it to the battery then program the flash sequence by
shorting the terminals on top. Once you first short the terminals, the
time starts counting and you have a specified amount of time (about 5-6
seconds) to program a sequence. As you short the terminals, you see a
visible green LED that indicates on. You tap out your sequence and
when the time is up, it stops accepting programming.
If you view it through night-vision scopes, you can see the pattern you
input flashing in IR.
assumption). I had originally thought 555 timer and shift register.
My idea for the design was that a timer clocks in your input to a shift
register. The longer you short the terminals, the more 1s are clocked
in. This results in a pattern of varying pulse widths that can then
keep cycling through the shift register and illuminate the LEDs.
I was unable to find similar circuits on the web, so I'm not sure
that's the right approach. I had although thought of individual
one-shots somehow keeping the outputs high/low with something clocking
them to change it based on what you input.
I can't figure out the "memory" of it, but I'd assume it's not
something complex -- that's why I keep thinking "shift register". For
it to work though, it would have to be many bits wide. I found some
8-pin ICs that have 16-bit serial registers in them, so if the duration
of the one-shots output is 1/3 second, then the shift register would
support a 5-second programming duration.
Any ideas?
Thanks.
which I'm assuming are simple off-the-shelf logic (could be a badFrom the look of the commercial device, there are only 2 ICs, both of
Any ideas?
Thanks.
