Programmable frequency divier (counter with reload)
L
litw
I am designing a 8bit programmable frequency divider (8-255) in tsmc.35
which operates at ~1GHz. should i use asynchronous or synchronous
structure? Thanks!
litw
K
Ken Smith
structure? Thanks!
Synchronous counters don't let the delays add up. Unless your flip-flops
have a delay under 0.125nS you need a synchronous counter.
You may still have trouble with the carry prop. times. Often you need to
add an extra flip-flop for a partial carry and another for the divided
output.
L
litw
Thanks Ken! I guess I'll try the synchronous. Problem is that I do not
have a fast JK ff yet. There's several approach to improve async
dividers in paper, but I am not sure how I'll implement their ideas.
Anyway. I am learning. Thank you.
litw
K
Ken Smith
Most of the async tricks only work with fixed divide ratios that can be
expressed as a product of small numbers.
