Platforms
Content
I am unfamiliar with spice - is AM1 a non existent ammeter as far as the circuit is concerned?
No, not at all. And I am quite capable of posting barbed comments too. As you say, it's a disagreement about design considerations. I did find weaknesses in the design, and I should have thought about it more before I posted my initial response.Hello Kris. I re-read what I posted because sometimes, ..actually most times, what I'm thinking vs what I'm writing comes across as a bit demeaning. If you interpreted it as such it was not intended that way at all. This is merely spirited discussion that is typical among all technical and scientific fields of study. It's the food of the mind that keeps our dendrites firing.
Right, it is designed to a fairly closely controlled current budget. That is a deliberate compromise, because increasing the available current increases the power dissipation in the zener, and the standby load power of the circuit as well. The input coupling capacitor shouldn't be any higher than absolutely necessary, and this means that the current budget has to be managed carefully. This is a design decision, and it's the reason why the LED was put in series with the relay coil, because the relay coil current is conveniently close to an appropriate LED current and putting it in series reduces the load power, because you don't have a series resistor wasting a lot of power.Regarding placing the Orange LED (Led2) in parallel with the coil .. opposed to in series, as in the original circuit: I recommended this change because it's the most orthodox method. You'll note in my last schematic I posted I placed it in series. If it weren't for this feeble power supply I wouldn't have, but this thing has no (current) overhead at all. It's being milked as it is; even with the original 24V/1.2KΩ relay coil.
We have both pointed out that the zener voltage is too low to get 24V average across the coil, because of losses in the 1N4007, the LED, and droop due to ripple. I regard this as an error in the design. Putting the LED in parallel with the coil will only fix one of those four issues, and the increased load current would deepen the ripple, causing a further reduction in average coil voltage that could easily outweigh the 2V gained by moving the LED out of the coil circuit. The design needs to be fixed, by increasing the zener voltage and possibly other changes. Then, having the LED in series with the coil will have the intended advantages of reduced load current and less wasted power, and it's the winning option IMO.Speaking of the original circuit.. The original 24V relay coil could never see the 24V that it was intended to operate on. The 24V Zener won't let the + rail go higher than that; minus the drop across Led2 and its shunting resistor . When the contact current is very high it's imperative that a relay coil (pull in force) be optimal. So yes, I understand why the LED is in series, but is it good design? No, not in a good power supply that has overhead.
Sure. My explanation was for Paul's benefit.Regarding the resistor in parallel with the Orange Led (Led2): It should be obvious that I understand its function. After all, I modified its value in my last schematic to reflect use of the 12V/300Ω relay coil. I lowered it to shunt more current around the LED and keep the LED current close to 20mA.
I don't like the idea of using a lower voltage relay, because again, the required current is higher, and this circuit is designed with a specific current budget. Increasing the available current increases the dissipation in the zener, and the standby current of the circuit. I think 24V is a good compromise for the derived rail average voltage, and the relay coil.You will also note that I added a resistor in series with the coil to insure that the coil is dropping close to 12V.
The whole circuit already has to be isolated from ground. You can't ground the negative rail in the original circuit - it's connected to Neutral. The relay provides the output isolation, and the optocoupler (which I keep saying is necessary) provides the input isolation. As long as the input and output are isolated, the circuit can have its negative rail connected to Neutral, or just as easily, to the output of a bridge that connects to the mains (via the input coupling capacitor). The whole circuit needs to be physically isolated, which is why I suggested encapsulation, or partial encapsulation.Regarding a Bridge: Certainly a Bridge would be an improvement, but how are you going to do that without a power transformer? To incorporate a Transformer-less Bridge we would have to place the negative rail of this circuit at 338V (Peak Voltage) above earth ground. On the other hand, if we had a power transformer we wouldn't have this circuit at all and would be dealing with conventional power supply design.
Those concerns are taken care of by the design. The feeder capacitor needs to be AC-rated - the kind that is used for suppression. With all the markings from UL and the other safety labs. The resistor in series with it will be a fusible type, so if the cap was to go short somehow, the resistor would pop its clogs in very short order, while limiting the peak current, and the zener would protect the rest of the circuit.Finally, my dislike for this circuit, besides all of the above is this.. The dropping capacitor (C1) is a weak link. Transformers rarely fail and all UL rated transformers are internally fused on the primary. Capacitors, on the other hand, especially ones subjected to higher voltages, surprise no one when they fail. They don't usually open, but instead leak, or worse yet, short. In this case, if C1 broke down and shorted the mains voltage would run though this entire circuit like sh!t through a Goose! I don't think a single component would survive the blast.
LikewiseJMHO
Ok friends.
Here is what I have decided to do:
Get an original 24v 1200R relay and just increase the 1u cap to 2.2u. <snip>
Does anybody see any problems with this?
The zener is a 1W zener FYI.
-Paul
Likewise![]()
You're not supposed to rely on that. Any circuit that is galvanically connected to the mains (whether to Phase, Neutral, or bridge rectified mains) must be considered to be potentially live and must be isolated.The only difference between neutral and ground is that neutral is a current carrier while ground isn't. Back in the distribution panel it's the same node.
That's right, if you use a bridge, the common rail of the circuit is guaranteed to be live. My point is that the circuit should already be isolated for safety reasons, because it must be considered to be potentially live, because it is galvanically connected to the mains. NOTHING ELSE should be galvanically connected to that circuit. It is NOT SAFE to rely on the common rail being at ground potential! See my edit to my previous post.I'm not the one who suggested a bridge. I don't care if we're talking ground or neutral. Please show me how you would use a transfomer-less bridge in his circuit without his common rail ending up 338V above mains neutral or ground. I say not happening.
Ok friends.
Get an original 24v 1200R relay and just increase the 1u cap to 2.2u. In my sim I get 22v 18mA on the relay which should be enough. before it was about 18-19v and too low which fried the contacts due to heavy current switching.
Only 1 component change (and the replacement relay) and fingers crossed.
-Paul
