Hi. I'm hoping someone can help with this fault on a Toshiba 26DV615DB LCD tv. Symptoms are as follows:
This is a fault which just appeared one day out of nowhere. The tv appears to start up normally, but usually displays a blank, dark grey screen. (The backlight is on). Sometimes when I switch on it will show a normal picture, but it is frozen. Over a period of about 20 to 50 minutes, the display will gradually change. For example, if the frozen picture is displayed, it gets brighter, until the picture starts turning negative, then fades to grey again. This may happen about three times during the time period. Later on in the time period, it may start to show signs of an active picture, but it is obviously completely out of sync. The sound is normal throughout.
After this, a flickering picture will start to appear, which gradually gets more stable, then finally a normal picture appears which stays that way until it is switched off.
I had a spare LCD video board, which I fitted, but the symptoms stayed the same. So all that's left to suspect is the CEG 376C power supply, or the LCD itself.
I'm not aware of an LCD fault which would cause these symptoms, so I suspect bad capacitors on the power board causing one of the supply voltages to be low. The caps themselves look ok, but I can find very little info on the CEG 376C, which is a standard power supply used by many manufacturers.
So if anyone can point me in the right direction, or has a schematic for the power supply, I'd be very grateful.
Thanks, Greg
Thanks, Greg
