Hi all - this is a really cool forum you guys seem to have!
I've been interested in electronics probably about 25 years now in terms of pulling things apart and fixing radios etc when I was a kid. Used to make my own etched PCBs for projects but am very rusty on it all these days.
Anyway, I decided to build my own ipad/iphone charging speaker dock which will run the audio from either device into an amp and speakers.
I'm doing some basic wiring on the dock connector but am really baffled as I cannot get a charge through to the phone for some reason, so am hoping for some help. I hope this is the right subforum, but apologies if not!
Usually the phone or pad will charge with +5v from USB. So I am using this as a test source.
This is the dock connector I am using:
Now when I apply voltage from a USB connection (5.7v measured) to the red & black wires I have soldered to the board, the phone does not begin charging. If on the other hand I connect a USB iphone cable directly to the rear socket on the board then the phone starts charging no problem.
I have measured that in both cases, there is the required voltage reaching the relevant pins on the connector at the front, where the phone is connected, so I cannot fathom why it charges when I plug in the proper connector to the board, but not from directly applying voltage to the board, even though both situations give the correct voltage as going into the phone connector.
I'm sure this must be something noobish that I'm doing wrong here, but damned if I can see what, when I can see the required voltage right there on the same pins, but no charge commencing.
If someone could help suggest why this won't work I'd be really grateful!!
BTW - gnd can be found on the metal of the connector, on the solder at the left, the middle pins (15/16), and +5v is measured at the 3rd pin from the right in the group of 4 (pin 23).
This is a theoretical diagram for what should be where, and indeed is, but it's not working for charging somehow.
Many thanks
Jim
Many thanks
Jim
