Sir mike1856 . . . .
Indeed . . . you have found the Speaker cut out relay . . .our item of interest.
This unit may not be exactly like yours but you can see the marked on connections of interest.
This unit needs 24VDC to be at the GREEN pair of terminals in order to close connections between the marked
Right amp output contact to the Right speaker contact
and simultaneously, the
Left amp output contact to the Left speaker contact
Then the unit has connection from amp to speakers.
Unless the overload circuitry keeps that relay coil from activating.
If you place DC metering at its 50VDC range . .or greater . . . and ground your black negative meter lead to the metal chassis.
Then the application of the red meter lead to the GREEN terminals should show 20-24 VDC being there after turning on the power of the amp.
Then you can try the red and black meter probes across the two green terminals to see if 20-24 volts across them results after turn on . . .wait a full 15 seconds to confirm.
If the relay clicks in and then out,
Leave the unit on and move the black lead to metal chassis ground, Place the red meter lead to each of the 4 other terminals on the relay to see if there is any DC voltage on them . . . .as low as 2 VDC being on them could be related to the units problem.
73's de Edd
73's de Edd
