Platforms
Content
I think an open source laser engraver can do the trick without expensive parts.a low power laser diode will make the cnc engravers as printer (prusa i3 as an example).
you can even make it by some scrapped CD/DVD Roms and an arduino board for small printing projects.
Which is best option microcontroller (raspberry ) or PC to print on cartoon box ?
Please take look at this link https://www.domino-printing.com/en-in/products/g-series/i-tech/g230iThe best option will be the simplest (potentially cheapest) option.
If the printer uses a standard parallel port (or USB) then a cheapo PC running the appropriate software would be required. Otherwise you're looking at the construction, interfacing and programming of a dedicated module.
If you already have the printer hardware, what is (or was) the original controlling device?
I have already given example. What you want to know ?You don't really tell us what it is you want to achieve.
My question is what should i use PC or Microcontroller to control printer because I found in google search we can use both PC and microcontroller But I want to use best oneconsider there are the bunch of cartoon moving one by one on belt, if cartoon detect by sensor then print serial number on cartoon
sensor --> PC/MCU--->Printer
And your definition of 'best' is ........?But I want to use best one
Best one means it shouldn't hang while workingAnd your definition of 'best' is ........?
Most reliable, easiest to program, simplest to service, ...... or what?
But one program is already running on printer to print textYou need to program the computer to read the sensor's output, count the output signals and drive the printer accordingly.
Printer have USB port and Computer also have USB port. Printer can connect to computer with USB cableJust Google for serial (or USB etc) interface unit. They are usually supplied with controlling software.
Nor do we, until you tell us what the sensor output specification is and what sort of computer port will be used to read the sensor outputBut I don't have any idea
Printer have USB port, Printer can be connect to Computer using USB cablewhat sort of computer port will be used to read the sensor output.
A link to the sensor datasheet would be helpful.
That doesn't answer the question of which computer port will read the sensor.Printer have USB port, Printer can be connect to Computer using USB cable
