Gus said:
Robert: I like the idea of using the expansion modules you suggested.
Would you use one per zone, or each side of a house, or a group of
windows?
If the idea of using these modules is to make trouble shooting easier
then all modules would have to be grouped near the attic access
door....this is a gable roof and I may not be able to crawl very far
to a module. Also the insulation is R-38, about two feet of blown
fiberglass.
Zone expanders can be mounted at any location (inside a closet for instance).
You don't even have to know how many you need and can expand the system at any
time (as long as you've run all the individual zone wires to each expander
location). On a three story house, you may require only eight zones for the top
floor for instance. Accessible windows or doors, smoke detectors, and glass
breakage sensors. You may even consider wiring your main control unit in the
master bedroom closet. Don't forget to run some CAT 3 telephone wire from here
to the main telephone drop at the side of the house. On the main level you may
need more zones and I would suggest putting the zone expanders required in a
metal lockable enclosure in another closet on that floor. If you figure you
need an additional power supply, run an 18/2 cable for the low voltage AC you'll
need for it. You can buy enclosures that are sized to accept an additional
battery. Most expandable controls use supervised power supplies. Don' forget
to run an extra 18/2 cable between the main control and any expansion cabinet so
you can common the negatives of the panel's aux power and the extra power
supply. The same goes for the basement. Some clients have opted to build a
"mortgage helper" suite in their home and wiring an expander into it would be an
excellent choice (along with an extra keypad run).
I am having a problem finding a expansion zone module on your and
other web sites. I assume these are just some kind ot terminal block.
There are several other online dealers you might consider as well. Some are
listed here:
http://www.yoursecuritysource.com/buyingonline.htm
Thanks for your help, I was thinking of a simple 8 zone alarm.
Which is *not* a good idea. You can go "cheap" if you want, but I'd suggest
sizing the alarm control to the number of possible zones in the system. The
cost of the control and expansion modules you'll need are not significant. Good
luck!!
