Prewire Help Needed
alarman
I'm trying to prewire my new house for window contacts, and I've got a
good supply of 20/4 thermostat wire. Will this cause any problems?
20/4 is a little heavier than what is normally used for door/window
contacts, but it will work ok.
I'd buy burg wire (22/4) for the doors/windows, and use your 20/4 for the
keypads, motions, sirens.
js
Crash Gordon
It would be a real pita to work with.
Jackcsg
Keep in mind, thermostat wire is made up of all kinds of metal, mostly
scrap. It's designed for short low voltage AC runs. It will work, but down
the road....
Jim
It's a little thick to work with and not very supple. Save it for the
power runs. Siren, AC.
22/4 is the commonly preferred wire. It's the plain old telephone wire
(POT's) that you've likely seen used for years for telephone hookups.
Easy to use, flexible, jacketed, with a pair of spare wires to each
location. Wire will be the least of your investment, so don't skimp on
it because once it's installed you'll never have to consider it again.
From that point forward, any faulty alarm component can always be
changed with little difficulty. Wire should be forever.
Thanks for the replies. I wanted to use 22/4 to start with, but I live
in a small area and none of the electrical supply or hardware stores
carry it. The only phone wire that I could find was 24/4 and I thought
that I needed to use at least 22/4 for contacts.
alarman
Internet + UPS / FEDEX / DHL + credit card = 22/4.
If you live in River City, try the Wells Fargo Wagon.
js
Crash Gordon
Home Depot sells 22/4 station wire..at retail. Don't use 24/4.
ssab
As the others have said the 20 is a little stiff. If the runs aren't more
than 50 ft or so you could use the 24 as would be the case in most diy home
prewire if the panel was centrally located. good luck with your project.
