Precision low frequency generation
  • Thread starter Dirk Bruere at NeoPax
  • Start date
I'm thinking of creating a precision low frequecy generator (<20HZ) by
taking a computer generated stereo sinewave output with (say) one
channel o/p 5000Hz and the other (say) 5002.5Hz, feeding into a
summing input of an op amp and then putting the signal through a low
pass filter to recover a 2.5Hz sine wave. Do you think this will work,
or have I missed something?
Dirk
Mark
Dirk
if you are making a linear summing amplifier, then YES you have missed
something, the difference between addition and multiplication.
Mark
Phil Allison
"Dirk Bruere at NeoPax"
** Yep - the regular, prescription, anti-psychotic drugs that keep you
just inches away from committing suicide.
Please do continue as you are ......
( Wot a ** fucking MORON ** )
....... Phil
...... Phil
You're projecting again Phil.
Dirk
Dirk
A whole lot simpler to produce the 2.5Hz signal directly from your
computer.
V
Vladimir Vassilevsky
Wow. You don't have a slightest clue, do you?
VLV
computer.
I need to use any computer, without specialised hardware.
Soundcards typically will not go down below 10Hz.
I suppose I could simplify it by generating a high frequency sine wave
100% amplitude modulated with the low frequency component in something
like Audacity.
Dirk
John Larkin
Dirk
You'd get no output at 2.5 Hz. You need a nonlinear mixer ahead of the
filter, ideally a linear multiplier.
John
Dirk
Dirk, to get the difference frequency you need to multiply, not add,
the signals.
Here is a cheap man's solution:
0V --potentiometer-- +12V +12V
100kOhm 2200 Ohm
C 1 |
| C4
f1---- 100nF----------------g2
drain---------------------------- 100uF---------------- out
BF961
C 2 dual gate MOSFET
1uF
f2---- 100nF----------------g1 source-- |
C3
100kOhm
C1 and C2 decouple the input.
The potentiometer sets the voltage at gate2 so the drain is at about
7V.
The 2200 Ohm together with C3 form a lowpass.
The second gate in the BF961 dual gate MOSFET modulates the signal
caused by the voltage on the first gate.
Here is a similar diagram, note the mixer, it is for higher input
frequencies however..
http://panteltje.com/panteltje/lorentz/experiment.ps
Select C3 for adequate low pass filtering.
Does output need to be a precise sinewave?
If so, use an EPROM with a binary counter on the address lines, driven
from a 74HC4046 VCO, output
EPROM into a simple DAC.
E
Ecnerwal
Given that you are adding "specialized hardware" in the form of external
circuits, why not just make the external circuits be a ROM full of
digitized waveforms and a DAC to spit them out? You can get a uP that
has both enough ROM and a DAC on-board...
Jan Panteltje
On a sunny day (Tue, 20 Nov 2007 07:25:00 -0800 (PST)) it happened
[email protected] wrote in
<2cccb7f8-56d7-4b7e-903f-350c7b819a6a@b36g2000hsa.googlegroups.com>:
Google screwed up my ASCII art, so here again from a real newsreader;
Dirk, to get the difference frequency you need to multiply, not add, the signals.
100kOhm 2200 Ohm
C 1 | | C4
f1---- 100nF----------------g2 drain---------------------------- 100uF---------------- out
BF961 |
C 2 dual gate MOSFET 1uF
f2---- 100nF----------------g1 source-- | C3
100kOhm |
The potentiometer sets the voltage at gate2 so the drain is at about 7V.
The second gate in the BF961 dual gate MOSFET modulates the signal caused by the voltage on the first gate.
Here is a similar diagram, note the mixer, it is for higher input frequencies however..
If so, use an EPROM with a binary counter on the address lines, driven from a 74HC4046 VCO, output
<2cccb7f8-56d7-4b7e-903f-350c7b819...@b36g2000hsa.googlegroups.com>:
100kOhm 2200 Ohm
C 1 | | C4
BF961 |
100kOhm |
Thanks.
Initially I need to test with sinewaves, but ultimately I want to use
the computer to generate arbitrary LF waveforms.
Modulating a HF signal with the LF waveform in the computer would seem
the best way to go initially. Then it becomes an AM 'radio' problem.
Cat's whisker?
Dirk
V
John,
why did you sell him an ultimate arb generator?
VLV
DJ Delorie
but ultimately I want to use the computer to generate arbitrary LF
waveforms.
Put a DAC on the parallel port, or buy a DAC dongle that plugs into
USB.
That would be a good solution for a standalone unit.
However, I like the idea of selling custom PC progs for specialised
generation for the app I have in mind.
The money, as usual, is in the s/w
Dirk
