I am attempting to repair a Mackie (TH-15A) powered speaker's amplifier. After opening her up and referring to the schematic I found a few burnt components. It seems a resistor in the +-28V supply just off of the step-down transformer is slightly burnt, no other visible issues in this part. See attached image1 (R121). FYI main bridge rectifier is providing correct 300V DC.
Also, the final amplifier chip (TDA7294) as well as the resistor on its output is burnt. See image2 (U200 & R212)
I have ordered replacements for the burnt components, but don't want to slap them in to see them burnt again. I figured I would isolate the power supply portion first and make sure I get the correct voltage there, before connecting up the amp board.
My question is, would the power supply fault cause the amplifier chip to blow, or the amplifier chip fault cause the power supply to blow? Just looking for some insight from someone with more experience in these types of repair. Also, what is the best way to determine if any other parts of the circuit are damaged. Unfortunately, I only have minimal test equipment at the moment in a DMM.
Thank you for anyone who can help!
Joe
Joe
