i cant afford to build this concept, and i havent gone to school for it yet either (looking to start in the winter, but i think fall hours are closing next month and i missed the window).
first of all..
i want to dive into the deepest thought about whether this concept is generally healthy for batteries.. because it might not be.
yes it might seem like a great way to extend the life of batteries inbetween solar panel charges .. or maybe an investment worth looking into for solar panels that have become much weaker since they were new (if that happens, i dont know.. only an uninformed & inexperienced guess).
because if batteries are meant to dish out a specific voltage, general concept theory says the voltage will be the same.. but the amperage draw would be less.
what might not be idle function..
maybe the battery trips, falls, doesnt want to get back up without being put on a machine to revitalize the insides.
i have a somewhat hard time saying which reason the concept is for..
because there are things in use usually on a daily basis that it would help with.
electric stove
electric water heater
or the entertainment devices in the living room.
obviously some suck up more power than others when they are on... but sometimes the amount of time they are on amounts to more or less than the others.
anyways..
this concept might not make a whole lot of sense if your electric bill isnt high to begin with, because of being on the natural gas for the water heater or stove.
lets say it is for a stove.. you start with 240 volts input .. immediately you need to know how many amps to deal with.
then you step down that 240 volts with a transformer (with the needed amperage allowable)
bringing it down to something like 12 volts for maximum savings.
then you need to boost the 12 volts with the magic of the magnet instead of drawing in electricity that makes the monthly bill higher.
bringing it back up to the 240 volts with the needed amperage allowable in the coil .. ground is ground like having a grounding rod in the dirt with the wire connected to it (because if you did, that is where it would go)
it might not be exactly 12 volts.. but somewhere around there is what you are pulling from the line to power the stove.
i went on ebay looking at electrical stoves to note how much power they draw.
i seen one that was about 3,000 watts
i seen another one that was about 4,000 watts
then i seen some of those tankless water heaters and they want something like 120 amps on three circuit breakers that add up to 150 amps.
what i like to think about amperage is.. the voltage might be there, and you can stare at the voltage in the doorway all night.. but the moment you try to talk to the voltage, it will fade away like gas or a ghost.
i seen mostly 200 amp circuit breaker boxes.. and some 100 amp circuit breaker boxes.
as i was peddling alone thinking about wiring up one 120 volt concept box with enough amperage to satisfy the electrical box.. it became clear two things:
1. how to install the box safely
2. realizing exactly how dangerous they can be
enough voltage without amperage can cause damage.. probably more than the 120 or 240 volts from the wall.
but amperage is what gives the electricity its power to cause damage.
when a coil puts out 200 amps.. there isn't a 10 - 15 amp circuit breaker there to protect you (especially if the device connected to the concept needs roughly 200 amps)
thus.. the concept box is certainly not something you can toss behind the stove.
i think this is where electricians come to enjoy their metal conduit as much as they do, because it keeps the consumer far enough away from the danger.. when usually the only danger is the power line coming into the house that goes into the breaker box.
i would imagine the line goes in to the house.. through the main breaker.. out to the concept box.. then the goofy problem arises, because you cant touch the circuit breaker rails twice...
that would require a box to hold the main circuit breaker as the line comes into the house
then run it to the circuit breaker with its second main breaker (saves the concept box)
then all the circuit breakers on down as usual.
it makes me ponder & giggle.. because saving $30 - $50 per month isn't the same as saving $100 or more.
i think $50 is kinda pushing it really.. and $75 would be fantastic too.
i lived in an old house were the insulation all fell in the walls.. my mother and i ran up a $500 gas bill in a few short months.
seems like the gas is the culprit to avoid.
and when you begin a journey.. the end of the journey is being totally off the grid where blackouts happen but your house still has electricity.. especially useful if you are willing to help matters any as if providing a service for your community.
i think many of us doing really consider what the threshold is for the power going out and people knocking on the door looking for light or electricity.
something as simple as a power strip outside (or even a couple of 'em) to allow your neighbors the chance to charge up their cell phone.
maybe allowing people to bring over their microwave and cook some food if they were stuck with an electric stove.
it should be practical & free considering you are getting the power from the sun.
and i'm not saying help everybody until the batteries go dead.. because that adjective is where the help stops.
my internet must be filtered.. because i'm not getting enough transformers showing up in my web results.
i recall the possibility to wind your own transformer.. and that might prove useful filling in 120v outlets since they are all 20 amp circuits anyways.
a circuit breaker on the device should heat up faster than waiting for 30ft of cable to heat up.. because i do imagine it works like a thermal conductor a little bit for the circuit breaker.
i'm not saying the savings will be enough to finally go out there and buy a used xbox 360 to play with.. but we might not be with a choice.
this is how entire intelligent families start to save some money and put it together into one lump sum that might help change the world (an accessory to help perhaps.. but maybe the cost of simply being there staying in a hotel is all it takes .!)
maybe it leads to investment opportunities.
investments state one of two things:
1. the product gets more heavy duty thanks to more investors
2. the product exists to expand a menu when otherwise it wasnt going to be there at all
the only way to flip profit is to start low.
nature, time, & patience are the three biggest healers
first of all..
electric stove
anyways..
