Hello,
Is it possible to give a delay of 20mins upon power on before a LM555
can be used as a oscillator in its astable mode? I am designing a
circuit which has to follow this sequence: -
step1: On application of power to the 555 its output should be 0volts
step2: Upon completion of 20mins the 555 should start to give pulses at
its output.
step3: On completion of 20mins the output of the 555 is given to the
gate of a triac to fire it up.
thanks is advance.
Hi, Kfel. From your earlier conversation, possibly this might fill the
bill (view in fixed font or M$ Notepad):
| VCC .--------------------.
| 16| | VCC VCC |
| VCC .--o---------------------. | + + |
| + | Vdd | | | | |
| |.01uF | | | .-. .--o--o--.
| --- | | | | | | 8 4 |
| --- | |3 | | | | RST |
| | 12| CD4060 Q14o---o '-' | |
| o-------oRST | | | | | To
| | | | | o----o7 |Triac
| .-. | | .-. | | 3o-->
| | |10K | | | | .-. | 555 |
| | | | Vss | | |15K | | | |
| '-' '--o----o-----o------o---' '-' | | .-o6 |
| | 8| 11| 10| 9| | '-' | | |
| GND GND | | | |56K | V o--o-o2 |
| | | | | | - | | 1 5 |
| '-' '-' | 1N914| --- '--o--o--'
| | .->| |100K | | === GND
| | | | | | | GND
| '-o---o--||--' |
| | ||1uF |
(created by AACircuit v1.28.6 beta 04/19/05
www.tech-chat.de)
Sorry you can't do this with a 555 alone, but 20 minutes is just too
long for +/-10% accuracy. As an alternative, try the CMOS CD4060 along
with your 555. The 4060 kind of revolutionized industrial time delay
relays back when the earth's crust was cooling, and it can work fairly
well for your application, too. Look at the data sheet for reference:
http://www.fairchildsemi.com/ds/CD/CD4060BC.pdf
Internal to the 4060 is the makings of an internal oscillator, which
can be set up either with a crystal or an R-C network. The components
above are chosen so it will oscillate at between 3Hz and 9Hz, depending
on the pot setting. You'll have to tweak it in, because the frequency
of oscillation is somewhat dependent on power supply voltage (you do
have a well-regulated DC power supply between +5V and +15V here,
right?). Look at one of the intermediate outputs, and tweak it in with
a frequency counter if you want exact results.
The thing is, to get +/-10% repeatability, you'll need a cap that can
do that. Your repeatability is going to be almost entirely dependent
on your cap. I'd look at mylar or one of the polys -- stay away from
electrolytics and tantalums.
Anyway, after 20 minutes, the Q14 output will go high. That will
forward bias the diode, pumping current into the summing junction and
swamping out the oscillations. The 4060 will stay stuck until you
cycle power, which is what you want. It also puts the RST input of
your 555 high, allowing it to oscillate, and drive your triac as
requested.
By the way, as a simple precaution, make sure the 1N914 is shielded
from light if it's got a glass case. Light will mess up the diode
leakage current.
Would you like fries with that?
Cheers
Chris
