Power Google Home Mini
Im trying to power a Google Home Mini at the end of about 60 ft of wire (4 pr 18 gauge) double the pairs
I have tried
Using a 5v 2amp power supply (at the end the voltage drops below 5v google home will not boot
Using a 5.8v 1.8 amp power supply with a diode or two to drop the voltage the google home will reboot after a few min
Using a 12v power supply to power a USB car charger (5v 2amp output) Google home will reboot but run for at least 10 min
Any suggestions
I was thinking about using a LM7805 Voltage Regulator and power it with 12v. Not sure how much heat that would generate. It would be inside of a wall where I mount the google home
Sketch out a circuit of what you have and are trying to do.
Your explanation is just confusing.
Details of the load volatge and current requirenents also will assist.
i.e. I for one have no inkling of what a google mini is or any parameters.
Google Home Mini is in Internet WiFi connected speaker Its power requirements are 5v 500ma
All i'm trying to do is power the google home mini on the end of 60 feet of wire
davenn
yeah you are suffering voltage drop
do this variation But WITHOUT any diodes ... one diode will take you to 5V and you are back where you started
2 diodes will take you well below 5V and you are worse off ....
you will loose that 0.8V in the 60ft of cable and should hopefully still have 5V at the end of it. if you don't, then you could try a 6V supply
Dave
If you have 12V at 500mA or more and use a 7805 with capacitors at the google home mini then the google home mini will get 5V and the 7805 will heat with (12V - 0.8V - 5V) x 500mA= 3.1W. The 7805 will need a heatsink that is not enclosed.
The 5.8v power supply dips below 5 volts when I apply the load If i use a 6v (6.2v) power supply the voltage at the load is 5.9 so google will not boot If i add a diode it drops below 5.
When I use a 12 v power supply to power those USB chargers ( rated at 2 amp output) you get for your car and plug the google home into that the google home runs for a few min then reboots. Im not sure y thats happening.
Is it possible the USB car charger is poor quality and/or fraudulently rated for higher current than it is really capable of? I would measure its output voltage voltage under load, while the mini is doing something, say streaming music over wifi and playing it at high volume.
Assuming it will always be powered on, I would definitely go with a switchinig USB power adapter of some sort instead of a lossy linear 7805, as having to buy one would still pay for itself in power savings and not have to deal with heatsinking and an enclosure.
If you want to use a 7805 anyway for some odd reason, I would get a cast aluminum enclosure and just bolt it to that with grease. Some are even NEMA waterproof rated with a silicone gasket, but do mount the regulator to the bottom instead of the lid so it has the larger surface area to help.
There are people who have used a USB power adapter and found that the USB cable they chose was low quality and that voltage drop caused it to reboot.
davenn
OK
With the responses I read from them, I suspect Audioguru and dave9 were misunderstanding the problem .... and not understanding that it is a voltage drop problem over that 60 ft of cable
For the 6V (6.2V) supply was that measuring the voltage at the other end of the cable ?
1) You need to put the 6V supply on one end of the 60ft cable and measure the voltage at the other end WITH THE google unit attached <-- what then is the voltage ??
2) You could go the 12V way ... put that into one end of the cable. and the 5V regulator at the far end of the cable ( where the google unit will be)
dave9's suggesting to use a switching regulator rather than a 7805 is a good one
they are dirt cheap a few bux off eBay eg
https://www.ebay.com.au/itm/Waterpr...-Module/381462910417?var=&hash=item58d0f615d1
find a supplier closer to you, select the 12V-5V version ... done
you CANNOT put the 12V supply and the 5V reg at the same end of the cable ... it doesn't achieve anything
Dave
If you are using a 12V supply and a regulator of any type, the regulator should be on the end of the cable that is closest to the google home, AND you should have both input and output capacitors on the regulator. These capacitors are often (but not always) built in to the 12V car USB adapter and are external components other than the 7805 that you will require if you build it from scratch.
It's also possible that the power supply on the google home is more than a power supply. The power supply for a google chrome, for example, also includes some of the networking hardware.
Why not use a 5V power bank (rechargeable) at the local end?
5V at 500mA is only 2.5W and a 5000mAhr battery bank would power it for 10 hours - probably longer if it is idling for any length of time.
OK dave9
The USB car charger works good If I attach it directly to the power supply (1ft cable) Its when I move it to the end of the 60ft cable that I start to have problems
Last night I took the power supply that Google provided and cut the cord to have a look there is one conductor (+) and its wrapped with a shielded ground. Would that mean that trying to power the google with 5 or 6v the cable is picking up noise and doing something with the Google mini
davenn
yes I measured the end of the cable with load on 6.2 at supply and 5.9 at load when I add the diode it drops below 5v. Yes the 12v and the usb adapter are at opposite ends
kelly_eye
The battey bank isnt a go I want to install around 8 of these throughout the house. I cant go around and recharge all of them every 9 hours. But I was thinking if the cable is picking up noise y could I not feed power bank with 5v and at the same time run the Google Home off the power bank. I think I have seen them with a power in and a power out. But again the size is a problem
When I'm using the 12v feeding the USB adapter at the other end I monitor the voltage with the load attached and the voltage never drops below 12v but for some reason the Google Home Mini reboots after a few minutes.
Im going to try Cat 6 wire first with the capacitors like steve suggested and then if that does not work look at the switching regulator only thing with that is the size I would not be able to get that inside the wall without a huge hole.
Thanks Guys for your support
On the home mini it is just a power supply. Yes I was intending that the car USB adapter be on the end that the mini was on, with the assumption that hopefully it would have enough margin to regulate 5V after the 12V had dropped over the 60ft run.
Wait, "inside the wall"? I would just string mains AC to an outlet, and plug the mini's power supply into it. It seems useful to have mains AC there if there are people there to use a mini, no?
I purchased a usb car adapter at walmart its supposed to put out 3amp Instead of those dollar store ones I was using. Yup that is doable putting in an AC outlet. I put the mini up on the wall 1 foot from ceiling and the intent for other locations was to put it on the ceiling so those locations I could use a switching regulator in the attic just above the Google Home.
It seems there is a difference (dont know what) in the dollar store version and a brand name USB car charger. I have had it running on the brand name charger for about 20 min now and working ok.¸
So thank you for all your suggestions its nice to have input when things aren't working right.. If anyone wants to chime in on the difference between the cheepie and the expensive one Id be interested
Have a good day
