Hey guys,
It´s been a while since i´ve been to my last electronic class, so i hope you guys can help me out with this
I´d like to power a row of 10 CPU fans to enhance the efficiency of the ancient radiators (to heat) of my ground floor.
I planned to use 10 fans (80mmx80mm, 12V, 0,17A), powered by a 12V charger. I´d like to control the speed of all fans by a potentiometre.
I would have simply set all fans in parallel, so all of them will turn with the same speed (*cough* i hope thats right ^^)
I would have chosen the charger based on my rusty school electrotech knowledge...
My problem is to find the right potentiometre.
This is what i planned to order:
https://www.mindfactory.de/product_...x25mm-2400-U-min-24-dB-A--schwarz_746495.html
https://www.amazon.de/Leicke-Netzte...6PUNMu4-icbEeoxE-nUtR0gU6ksPO9V_kggXS-1B_iVOQ
I attached a pic with a circuit in case my description was confusing ^^...
My questions are:
Is it right to use the parallel circuit here...
What potentiometre do i need to control the speed of the fans (best one with commonly used values)
Is the powersupply suitable for this purpose... (If not what values do i need)
I already use some old fans powered by old phone chargers and it makes the room down significantly warmer, just in case you doubt all of this makes any sense :-D
Thanks in advance
My questions are:
Thanks in advance
