L
Lory
How do you calculate the output voltage of a particular power
amplifier model? They are most rated in watts such as
750W @ 4 ohm load.
I build a function generator using the IC XR2206. It's
current is so low I can't even drive a bulb of light
with it. So I plan to boost the voltage and current
by plugging it to a power amplifier. I need a voltage
10V or above. I wonder what is the average voltage
rating of a power amplifier. Is it dependent on the
wattage or power rating? How do I know its respective
voltage and current?
Thanks.
Lory
750W @ 4 ohm load.
Thanks.
Lory
