OK, you're using spice software. We can work with that.
There are a number of issues with your component values but we can't correct them for you. We can steer you in the direction of solution though.
The first thing you need to do is connect a Vcc source. Then have to recalculate your resistor values. Your collector resistor is lower than it needs to be and your bias resistors are too low too. That transistor is saturated. When you're done with recalculating the resistors you can then do the same with the two coupling caps. They're capacitance is too low also.
BTW... I kinda like Sir Chris.
Chris
