Platforms
Content
Can you use a 330 kΩ potentiometer and limit the rotation mechanically to 90 °?
I'm not aware of 90 ° potentiometers off the shelf.
Resize to < 300 kB.I tried to put a picture of the connection but it doesn't work
Which model? Can you provide a link to the technical data / datasheet of the controller?I bought a bidirectional DC-motor controller.
Okay. Now pics work. This is also link https://quasarelectronics.co.uk/Item/3166v2-bidirectional-dc-motor-speed-controller-5-32vdc-5aResize to < 300 kB.
I already mentioned it above in the post. Because I want use joystick and the trajectory of the joystick is not enough.Hello,
Why do you need a 90 degrees potmeter?
The circuit uses a standard 100 k potmeter:
Bertus
Oh I guess I don't know how to do thatHello,
You can adjust the range for the circuit with the 100k and 10k resistors on adjusting stack.
You could make the circuit and measure the voltage on pin 3 of IC1a.
Then you can calculate the needed resistors in stead of the 100k and 10k.
Bertus
Hi, I would like to try this. Would it be possible for you to show (draw) how this is done for example in this picture you added?You're not alone in searching a pot with 90 ° rotation angle. All references I can find mention standard 270 ° pots with mechanically limited rotation angle. The ones that have "90 °" in the title of the sales offer refer to the angle between the pins and the potentiometer axle as 90 °, not the rotation angle.
In your circuit the pot is used as a voltage divider together with the 10 kΩ resistor at the lower end and the 100 kΩ resistor at the upper end. It thus delivers these voltages to pin 3 of IC1a:
0.05 × V+ when in the lower position,
0.52 × V+ when in the upper position
You cannot achieve this exact ratio by simple means. You can approximate it, however:
Using 4.7 k will give you these divider ratios:
- Remove the upper 100 kΩ resistor by a short circuit.
- Change the lower 10 kΩ resistor to 5 kΩ (use 2 × 10 kΩ in parallel or use 4.7 kΩ, good enough)
- Change the gain of IC1a from 1×to 2× by adding two resistors in the feedback as shown e.g. here. The value of the 2 additional resistors is not important. both shall have the same vale in the range 1 kΩ to 10 kΩ, whatever you have in your parts bin.
- Mechanically limit the potentiometer to move from the left side (lower pin in the diagram) to left side + 90 °.
0.1 × V+ in the lower position
0.72 × V+ in the upper position.
You can tweak (fine tune) these values by changing the gain f the opamp IC1a from 2 to another (lower) value. Do this by changing the resistor values in the feedback circuit according to the equations given in the link I providd above.
Okay, I'll try this tomorrow. I still have to ask if I understood correctly, so can I add those new two resistors to something between 1k -10k? ThanksHere you go:
