I am building a guitar effects pedal from a schematic online. It is all working fairly well upon initial tests although one of the potentiometers only appears to kick in (i.e. influences the guitar sound) for the last 10% or so of the turn. During that 10% the effect (sustain on this pot) cuts in and it works. I have tested the range of the pot in question and it does cover 0 to 100k so I don't think it is faulty. I wondered if this is a problem that can pop up in circuits using potentiometers and what might cause it?
Measuring the resistance at the point the sound kicks in, it is 50k (up to the 100k), so it is still utilising 50% of the range (seems to be about the last 10-20% of the the actual pot remembering it is a log pot and not linear). So its as if the lower resistances don't initiate the sustain effect.
The schematic for the pedal is HERE and as mentioned, the pot I am having trouble with is the Sustain pot.
A full run down of the problem including links to images and transistor voltages I have measured is posted HERE on the forum for the site that created the pedal schematic, if you feel that this extra information might help. I am asking the question on this site from a general 'troubleshooting potentiometer problems' perspective and so I am just looking for what the next logical test steps might be.
Also, I am using 100k log potentiometers that came in the kit, but after measuring their resistances, one of them (NOT the one in the above fault) appears to only get to around 60k. Is this the sign of a faulty pot? I read a tolerance of up to 20% should be allowed for which would obviously mean anything between 80k to 120k and therefore this pot is even out of of that range.
