First and foremost, apologies; this is probably the only time I'll use this forum as I simply cannot find the information elsewhere. Secondly: Hi!
My synopsis:
I have a small television that takes 12v 4A and to combat the problem of, you know, not having a power supply for it, I spliced together two 12v 2A adapters to create a Frankenstein's monster 12v 4A.
I know this was of course stupid; it's a short-term solution just to make sure the set actually works before I splash out on an adapter that will actually do the job.
My problem: The merged supplies seem to do the job brilliantly, but after some time the screen still blanks while the audio continues to play. There is no sleep timer enabled and flicking between sources results in only a momentary flicker of life before the screen dies again.
My question:
Is it possible for there to be some kind of current loss after a prolonged period of use, as a result of my using two spliced adapters; or is the set simply knackered and only fit for the recycling centre?
Thanks in advance (seems rather presumptuous, doesn't it?),
- Oxy
My synopsis:
My question:
- Oxy
