N_Cook
1.8mm slabs of porcelain under TO220 devices.
(This is continuation of Ampeg BA600-115, can of worms.
I've got mains back on it and is in working order , now to try with high
power.)
This is my educated guess as to what happened at manufacture as absent but
distinctive 20mm long bolt not found around here. The 4 output devices
should be held to the heatsink via a cross-bar over all 4 of them and 2
bolts thru it into the heatsink. The insulators are ceramic and the 2
central ones, butted up together , do not clear the retaining bolts on their
outer edges. After graunching the thread the assembler decided to leave it
out and trust to luck one off-centre bolt would hold.
Coming to reassembly I found a 3mm screw for replacement but it would not
hold, as tapped thread is stripped, so I tapped that one hole out to 4mm.
Tried grinding a clearance notch on the side of one pad but got nowhere as
ceramic.
Not only that but I had no trouble holding the slab in fingers while trying
to grind a slot , it was barely getting warm - good thermal insulator or
small grinding wheel not generating heat as not cutting into the material ?
So ,lateral thinking, decided to grind down the screw thread where it
interferes with the ceramic , on one bolt.
I wonder if this was a one off at manufacture or a whole batch like this,
all that was needed was shift a tapped hole 1mm, plenty of room there for
that. Or one ceramic pad 1 or 2 mm narrower.
ps
anyone use "chain mail glove" for small part in-hand grinding? At 80GBP and
upwards unlikely , firstly on cost, second need fingers for gripping items.
As an experiment wound some kevlar (ex fibre optic leads) around finger of
old glove and held in place with hot melt string. Simulated
grabbing/skittering of Dremmel and grinding disc into this on a piece of
dowel. It did not penetrate to the dowel, I expected the kevlar to snag and
stall the motor but cut clean through.
power.)
ceramic.
ps
