DoesThis Exist? Thermally Coupled Fuses
D from BC
Does that mean that cams and gears and belcranks
and linkages and solenoids, all connected together
to operate a 5 pound rubber mallet to smash the other
fuse when the first one blows, are out? :)
But seriously - can you gate the supply to the
second fuse with a mosfet only when voltage is available
from the first fuse?
Ed
A thermally coupled dual "mini" nonresettable fuse might be useful to
totally isolate a load if there's too much current.
When this would be needed...I dunno..but I'm trying to figure an
application.
If this complete load isolation can be done with semi's ...great..!
I should mention that I'm not looking for a solution but looking for a
seemingly imaginary part.
D from BC
jasen
Does this exist?
It's kinda like an optocoupler but only with fuses.
An input fuse and output fuse that's thermally coupled.
Or in other words...
A device that has two isolated fuses yet share the same heat.
When fuse A blows, it also blows fuse B or vice versa..
Since metal can't be used to couple the fuses together (isolation
wanted) maybe fuse A can ignite a non conducting dry chemical to burn
out fuse B.
D from BC
I've seen fuses that operate a switch when they blow.
But, if you're wanting the fuses to blow when the sum of currents
exceeds some limit, that won't work for you.
Bye.
Jasen
