Tom Becker
Folks, I've been working with a 4046-based shaft rotation tracking PLL
circuit. The source is a weak, noisy and pretty sloppy
inductively-generated shaft speed signal. I want to regenerate and
track it's principal signal of 252Hz, but that is punctuated with
occasional large and sometimes periodic low-frequency resonances and
gear noise.
The physical device is subjected to random accelerations from any
direction so while tracking it must remain responsive to pretty rapid
input phase and frequency changes - yet be able to flywheel though the
missing cycles caused by the resonances.
That seemed a challenge, but I have found reasonable success with simple
passive filters for some input conditioning, and for the loop filter.
While experimenting with active filters, though, I've found that any
low-pass on the input reduces responsiveness, thus tracking. As I write
this, I think I see that's due to any integrator eating time.
That suggests that whatever low-pass filtering I need should be done in
the PLL loop, not ahead of it. That leaves me with the low-frequency
resonance effect inside the loop, though, and that can ding the VCO
pretty well - producing a cycle-slip or breaking lock.
I'm tempted to try a twin-T notch or a high-pass to remove the low-F
stuff ahead of the loop, but I know I'm still playing with time. In
general - intending to optimize for tracking - should I try to clean up
the signal ahead of the PLL or be more selective in the loop filter?
Or am I off track? TIA.
Tom
gear noise.
Tom
