This is my first post in this forum and I would greatly appreciate any help that I can get.
I'm trying to identify a connector on the power board of a Walkera 250 Runner quadcopter? I've read that the connector is proprietary, but am hoping that a male plug can be bought. It looks like some sort of dual card edge connector. The pitch spacing (as best as I could measure) is 0.8 mm. Please see attached photos of the connector.
This is the closest that I could find so far:
http://www.farnell.com/datasheets/1838584.pdf
I would like to make a connection to one of the pins on the connector. If I can't find the right connector, I could solder a separate single wire connector to the solder joint on the board for that pin. Or maybe put a metal contact that aligns with the correct pin on a thin board that goes into the front slot?
If you have any ideas/suggestions, please let me know.
Thanks,
John
Thanks,
John
