A week or so (it seems, it may have been a month) I checked one of my el cheapo electric screwdrivers and it was telling me the battery was VERY low.
Having misplaced the charger, I've been promising myself to either find it or if something up.
Today it wasn't reading a charge at all. Worse, it wasn't accepting a charge.
Opening it up I find the cell was at 1.05V. not good. Clearly the charger prevents charging below some lower limit.
Well, what's the worst that can happen? I started charging it at 20mA and the voltage started rising. At 2V I increased the charger to 40mA. Eventually I had it being charged at 100mA with a voltage of just over 3V when the low battery warning started working again.
At this point I could again charge it via the charging port, and at 5.5V it was drawing a bit more than 350mA.
Also at this point, I extended the leads from my power supply so the drill can sit outside on paving bricks. If it catches fire, I don't want it setting fire to anything other than itself!
My research indicates that copper dendrites (the cause of catastrophic over discharge failure) don't actually form unless a cell gets a reverse voltage on it. The damage at deep discharge is limited to changes in the cathode which can significantly reduce capacity. Since it's a single cell, reverse charge won't happen.
I just checked it, placing it in a plastic bag (because there's a very small chance of light rain tonight) and the drill shows good torque, so the cell can handle moderately high discharge currents.
I'll probably replace the cell, because I'm not going to trust it now. At least a replacement cell is slightly cheaper than a new screwdriver :-D
