Still have issues
I had to leave the project for a while, but now on it again. I tried a 100k resistor without success. Just for the heck of it I rigged up a 60w lead lamp across the relay coil terminals, and that worked like a charm. When the PIR goes off, the relay drops out without issue, and lamp goes off). I tried my neon tester across the relay coil terminals (without the lamp connected), and when the PIR is open circuit there is a showing of about 50v, which is enough to make the relay light up and buzz. If I measuere the voltage without the relay in circuit, I think I recall that it showed around 200v (with PIR open circuit), but, this was with a neon tester. … I should really try again using a meter I guess.
So, it may be a quirk of the PIR that it passes a small leakage current if a small inductive load is connected. Strange!
I don’t want to have to “wire in” a lamp for two reasons. Firstly because where the board is sited, I don’t want a lamp that flashes on and off every time the external PIR is tripped, and secondly, if/when the lamp blows, it will mean that the PIR, and ultimately the whole PLC system which relies on it will be compromised.
So, I guess I am left to trying ever decreasing resistance using standard or wire wound resistors. Eve this is annoying in a way, as it is just another component to fit into the enclosure, and one that may require space and a heat sink, depending on how far I have to take it down.
I wish my understanding of electronics was better, as there must surely be a better way to do this?
I would try different PIR’s but that could be a common theme with them, also, the one I have was quite unique, in that it has a corner bracket as part of its make up. I also have a spare of the same, as the store had only two when I bought it.
If any of you clever sorts have any other ideas I might try I would welcome suggestions, else I will have to go down the trial and error route as stated above.
Thank you.
