Hello everybody
I wish to make a simple circuit, motion sensor to turn heaters on in my home, to help save funds during the cold winter months, and for a bit of fun to learn. I am a newbie, I know this is very very simple for most of you but it would be my most complex project so far
Goal: to build a simple motion sensor/pir circuit, to turn a relay on, with adjustable timing. e.g so I can adjust heater to stay on between 30 minutes to 3 hours, after motion is detected. I understand standard max heater draw is 1500 watts, so I will want a 15A relay?
I am trying to build this project from scratch, as opposed to picking up a cheap pir sensor from an old alarm system, even though that would be easier? My reason for doing it that way is simply I figured I would learn more...
Question one: Is it possible to keep the whole circuit 110v? e.g use a 110v pir instead of a 12v pir?
I dont know if its simple to include an onboard 110-12v converter? I wish to install this "inline" as my current heaters are hard wired. i.e I wish to avoid need to plug a transformer into an outlet, for space and simplicity and cosmetic reasons.
Question two: Adjustable timing: would I use an adjustable capacitor to get that sort of time range, or is there a better way?
Question three: am I better going with a solid state or mechanical relay? I estimate the relay would get tripped maybe 5 times a day, and be in the on position 10 hours a day.
Thankyou!
Lucie
Thankyou!
Lucie
