I want to mount the push button switch on the Speaker cabinet for switching on/off the PNG. I have called them power switches on my list which is probably a bit confusing. Thought the led on the switch would be useful for knowing the current state of the PNG.
Sure, you can switch the power to the noise generator on and off, but:
1. The pushbutton switch you linked to is a momentary pushbutton. It conducts WHILE you HOLD it in. It's not a push-on, push-off switch. So you would have to hold it in to keep the noise generator going! You need one like
http://www.digikey.com/product-detail/en/GPB527B2L02BR1/CW150-ND/2349745 which I describe as "push-on, push-off". Digikey call it "On-Off", as opposed to "(On)-Off" for the momentary type, where the brackets around "On" indicate that it's momentary, i.e. you have to hold the button in.
2. Turning the noise generator off isn't the same as disconnecting its output from the input of the speaker amplifier so you can put another signal into the amplifier. If you want to be able to do that, you really need to disconnect the output of the noise generator from the amplifier input. You don't really need to power down the noise generator, as far as I can see, unless you want to be able to restart the ramp-up without turning the whole speaker off. So you could use a push-on push-off button in series with the connection from the noise generator output to the amplifier input. If you want an indication of whether the noise generator is enabled or not, you could use a switch that has two clear positions, such as a toggle, rocker or rotary switch, or use a push-on push-off button with two poles (two separate sets of contacts) and an illuminator, with the second contacts used only to switch the illuminator.
3. As I said, if you want to be able to feed other signals into the amplifier, you need to disconnect the output of the noise generator. Even if the noise generator is not powered up, the output stage of the op-amp will partially conduct in response to the signal source you're feeding into the amp, and will cause that signal to be distorted.
I will use trimpots for the Op-amp gain control. I just knew it as a variable resistor before I looked at the component suppliers website. What sort of current do you think the circuit might draw just so I can be sure I'm picking components with correct ratings?
For the trimpots? They carry almost no current. Anything you find will be suitable. Ten-turn trimpots are available for very fine control and they'll probably be more stable when subjected to vibration. They take a long time to adjust though! You might want to get a trimpot adjuster, which is like a small flat-blade screwdriver with a skirt attached to it, so it doesn't slide off the adjustment screw.
The croc clips are just for testing purposes to supply power and take output to the amp. Thinking about it I probably need 8 in total. For testing I will just feed the circuit through the 1/4" jack input and run off an 12V battery. All going well I will hard wire the PNG signal internally to the 1/4" Jack input.
OK, remember what I said about disconnecting the signal from the noise generator circuit if you want to use an external signal source.
Just had another thought...I should keep room for a voltage regulator on the board just in case. Would it be worth just adding it to the board either way as I dont think the speaker manufacturer's are going to supply me with the schematic for the amp.
Yes, good idea. You might want to get some 78L15 devices, on the assumption that you'll be able to find a supply rail in the range 18~35V somewhere in the amplifier.
Edit: Check out this pushbutton:
http://www.digikey.com/product-detail/en/GPB527B2L02BR1/CW150-ND/2349745 It's way over-rated (20A current rating, probably meant for automotive use) but it has an illuminator and it has two poles (two sets of contacts).
