I'm trying to set up a toggle switch to swap between two resistive touch screen controllers on the same controller. I thought I could do it by attaching the 4 touch leads (X+, X-, Y+, Y-) to both controllers and toggling power to one chip or another but the powered down controller threw off the measurements.
So my next idea is to put a DPDT switch in between the two controllers and the negative leads and use that to switch the controllers. Hopefully this will work as I do not have enough room for a quad switch.
Any thoughts on this? Should I switch the positive leads instead?
Thanks!
Thanks!
