Rousty said:
Jim,
The HCU04 would be a good choice due to its single stage architecture
however the final design is intended to be in a hi-rel space
application and that will require a radiation hardened device like the
JM38510R75701SDA (i.e. the radiation rardened version of the 54AC04).
Unfortunately, there is no domestic source for radiation hardened
HCU04's so the AC04 is all we have. The feedback resistor that
establishes quasi-linear operation and allows for oscillator start-up
has been refered to as a linearizing resistor by personnel in the
oscillator business. It has two purposes, during startup it provides
for quasilinear operation so low level linear feedback loop operation
can occur (note that outside of the quasi linear region, the gain of
the inverter as well as the composit loop gain is zero). Operation in
the quasilinear region supports the growth of the intended oscillation.
Once oscillation has saturated the output (i.e. the limiting aspect of
the circuit), the resistor serves to provide approximate DC bias to the
input of the inverter. Note that these are two distinct and different
modes of circuit operation (startup and operating modes).
Thank you for your thoughts.....
Please don't be offended but you are seriously blowing it out of your arse.
It won't matter if your IC is RAD hard when it's in space and 'not'
oscillating. Before you try and bullshit your way through a bunch of rubbish
do yourself a favor and do a web search on crystal oscillators, in
particular have a look at what your crystal manufacturer has to say about
things.
You are using a digital IC in a linear manner and you are designing a
feedback loop to be nominally unstable at or close to the crystals
fundamental frequency. The only 'logic' IC's designed to work in this
application are unbuffered inverters with a single P/N channel stage. This
is because they will behave and can be designed to work in a 'predictable'
as a gain stage.
The only reason you may have seen it attempted with 'standard' gates is
because some asshole of a digital johnny didn't understand what U in the
part number meant and just saw the symbol and saw he had a spare inverter
knocking about the place so he used that.
Three months down the line all the product came back because the process
varied and the oscillators started not to. What is the UPS charge for
spacecraft recovery because you will be one seriously sick bunny if you try
it and it does not work. While you're at it do a bit of reasearch into
feedback loops and loop stability because, at the moment you are dribbling
about like some sort of loony.
If you want to make it RAD hard tear a piece off your tinfoil hat and make a
little house for it. I really dislike 'reasonable people'.
DNA
