I need a solution to transmit and receive some kind of code (simple, a word or so, just
to prevent too much false triggering).
- Two way operation is requested : one transmitter and one receiver on each side.
- Both transmitters don't have to operate simultaneously.
- It is not requested (but not a problem either if it does) that receiverA also receives
transmitterA and not only its source transmitterB.
- Activation by a NO-contact. Output stage activated as long as the contact is closed.
- Pauses allowed between two send-activations : max 200mS (so please avoid long
initiation times etc).
- Battery operation 4V5 max. Very little space available.
Hope the diagram helps.
I do not succeed in configuring the transceiver-modules nor in programming the pic's.
I already bought modules, but fail to fully understand the datasheets, so other types
may also be used. I think with the right pic's chosen, their total can be reduced to two
instead of the four in the diagram.
Hope someone knows this well enough to help me with connecting the SPI on the
modules to pic's, programming the pic's and configuring the modules.
Thank you.
Thank you.
