PIC flash controller IC in SOT-23 package
Activ8
No BOD module... I wonder which knucklehead made that decision.
Best regards,
Spehro Pefhany
No kidding. One of 'em's adv info, so maybe it isn't to late to
change.
If they want to change... change must come from within.
Mike Harrison
Agreed, but last time I complained to MCT about their BODs - even when they are present they are
power hogs, unuseable for most battery apps - he said that the reference takes up quite a lot of
silicon, which is why they weren't in the smaller parts.
Pity, as it means that many apps for the SOT-23 will lose 25% of the pins for a reset.
F
Fred Bartoli
Al said:
I'm waiting for a 3 pin version: one I/O, power and ground ;-)
Or 2 pins with muxed power and i/o. But you won't have to wait too long :
Onewire already exist.
Thanks,
Fred.
Al Borowski
Why stop there? Mux power, ground, and 8 bi directional I/O pins. Then
you will have a 1 pin chip :)
Al
W
Winfield Hill
Spehro Pefhany wrote...
Yep no BOD (Brown Out Reset Detection), no 8-bit A/D, no SIO, no
PWM, no EEPROM, no extra timers, etc. But it has an internal 4MHz
oscillator with a 1% calibration instruction, using factory data.
It's micropower (barely), 170uA at 2V = 340uW, typ, 700uW max (at
4MHz). It's small (without requiring painful ball-grid assembly)
and cheap, e.g. 55 to 78 cents qty 100 from Newark (no stock yet,
60-day lead time).
Of course there are many other serious contenders for very small
processors, some with much more capability, such as Silicon Labs
C8051F300 series, 25MIPS in an "11-pin" 3mm-square footprint.
http://www.silabs.com/products/microcontroller/mlp_matrix.asp
http://www.silabs.com/products/pdf/C8051F300_short.pdf
http://www.silabs.com/products/pdf/C8051F30xrev2_3.pdf
But then, the C8051F300 doesn't cost half a buck!
Thanks,
- Win
(email: use hill_at_rowland-dot-org for now)
W
Winfield Hill
Jan Panteltje wrote...
On a sunny day Winfield Hill wrote...
But how long will it take until we see the 1 pin chip? ;-)
I'd like to see a 5-pin SOT-23, can't be installed backwards!
Thanks,
- Win
Mike Harrison
I once had an ap that could have used a TO-92 PIC....
John Devereux
You would think so but that turns out not to be true! :(
F
Fred Bartoli
Sure.
Plus if the stripped pin is the VDD one, there's no risk anymore.
Thanks,
Fred.
K
Ken Smith
I want an 8 pin SO like this:
1 DAC output
2 ADC input
3 ADC input
4 Ground
5 ADC input
6 ADC input
7 DAC output
8 Vcc
I'll get them custom labled as "TIO72" and show them as a dual op-amp on
my schematics. I figure that should be lots of fun.
Spehro Pefhany
OTOH, the QFP-80 etc. packages that are symmetrical be installed 4
ways.
Best regards,
Spehro Pefhany
Joerg
Hi Mike,
Agreed, but last time I complained to MCT about their BODs - even when they are present they are power hogs, unuseable for most battery apps - he said that the reference takes up quite a lot of silicon, which is why they weren't in the smaller parts.
I wonder what they think is so complicated about brown out reset. Why do they need a reference? How about a poor man's brown out reset using a BJT or diode and resistive divider?
Regards, Joerg
Spehro Pefhany
Hi Mike,
When it's internal oscillator-only like this one, they could do a much
sloppier job and still have an acceptable circuit. All it has to do is
detect out-of-spec supply voltage before the processor is outside of
the guaranteed-operation range.
They could even limit the supply voltage range if the BOD is enabled
and still have a good product. For example, the BOD could have a
threshold voltage in the 2.0 to 3.0V range, allowing 3.3V or 5.0V
nominal operation without external circuitry and losing an I/O, in
applications where a BOD called for. In some special applications, it
might be acceptable to cycle the Vdd to the chip regularly or to
control it with a supervisor circuit.
Best regards,
Spehro Pefhany
Jan Panteltje
On a sunny day (Mon, 7 Jun 2004 17:30:47 +0000 (UTC)) it happened
1 DAC output
2 ADC input
3 ADC input
4 Ground
5 ADC input
6 ADC input
7 DAC output
8 Vcc
That is close to a PIC 16F675,
it has 4 channel 10 bits ADC and some analog out you can make with PWM in
software.
JP
Al
Al
Thanks,
Fred.
[/QUOTE]
Actually with the three pin version, you might be able to program it so
that a voltage on the input pin controls the current between the other
two pins. ;-)
Al
Jan Panteltje
Al
two pins. ;-)
Al[/QUOTE]
Already done, it is called transistor :)
JP
