Hello all!
I am trying to mess around with some electronics, and like it so far! Got a PICKit 2 with a PIC16f1824 to code on. And i got myself a breadboard, with some leds, wires and a ultrasonic sensor. The sensor has 2 pins, 1 for trigger, and 1 for echo. This is my assembly code, but it does not work. The red led does not light up, at all.
I can't see what i have done wrong.
The breadboard is working and all is connected correctly, as far as i can tell. I have tested with simply turning on and off leds.
The code i have so far:
Code:
#include <p16f1824.inc>
CBLOCK 0x70 ; DEFINE VARIABLES USED
d1
d2
d3
d4
Count
ENDC
ORG 0x00 ;RESET VECTOR
BANKSEL TRISA
movlw b'00000010' ;Setting all but RA1 to output, RA1 is input
movwf TRISA
MAINLOOP
CALL TRIG ;short burst to trigger pin
GOTO COUNT ;cout untill a signal is received
MLOOP
GOTO COUNTCHECK ;RA1, or echo, receives a signal, check how far
GOTO MAINLOOP
TRIG
CLRF Count
BANKSEL LATA
BSF LATA,0 ;trigger signal on
CALL Delay
BCF LATA,0 ;trigger signal off
RETURN
COUNT
INCF Count,1 ;increase by 1
CALL Delay ;delay 0.001 seconds
BANKSEL PORTA
BTFSS PORTA,1 ;checking if RA1 has recevied anything
GOTO COUNT ;loops
GOTO MLOOP ;RA1 received, go to main loop middle
COUNTCHECK
movlw d'6' ;gives w a value of 6
;movf Count,w ;
subwf Count,w ;count - w
BTFSC STATUS,C ;cheking c, is anything borrowed from w(nagative result) C is 0, nothing borrowed C is 1
;if result is 0, Z is 1(set), negative or positive is 0(clear)
GOTO REDLED ;turn on red led, Count is less than w(6) which means the obstacle is 1 meter away
GOTO GREENLED ;Count is larger than w(6), took more than 0.6 seconds before echo return, which means more than 1 meter away
REDLED
BANKSEL LATA
BCF LATA,3 ;turn off red led
BSF LATA,2 ;turn on green led
GOTO MAINLOOP ;go back to main loop, new trigger
GREENLED
BANKSEL LATA
BCF LATA,2 ;turn off green led
BSF LATA,3 ;turn on red led
Delay ;1 millisecond, 0.001 seconds
;993 cycles
movlw 0xC6
movwf d1
movlw 0x01
movwf d2
Delay_0
decfsz d1, f
goto $+2
decfsz d2, f
goto Delay_0
;3 cycles
goto $+1
nop
;4 cycles (including call)
return
END
