Hi guys.. appreciate some help please with a 12f675 project. A rotating wheel produces 8 pulses per revolution. For each second second a minimum of 8 pulses or more must occur. Should the wheel stop or slow down an output signal must signal an event by setting a port output low. I only use PIC assembly programming and MPLAB IDE templates etc. I've included my code which gives an ouput on GPIO,1 for every 8 inputs switched at GPIO,0 ( I use a pic simulator to check my programs)
I'm not sure how to combine my code into a 1 sec time frame, so as long as 8 pulses or more occur every second then OK less than 8 is bad. I thought along the lines of maybe a 1 sec period is reset on every 8 pulses but whenever the number of pulses fall short of 1 sec an output signal is flagged up. Any help with an example code would be appreciated.
LIST P=12F675 ; list directive to define processor
#INCLUDE <P12F675.INC> ; processor specific variable definitions
__CONFIG _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
;***** VARIABLE DEFINITIONS (examples)
;example of using Shared Uninitialized Data Section
INT_VAR UDATA_SHR 0x20
w_temp RES 1 ; variable used for context saving
status_temp RES 1 ; variable used for context saving
RESET_VECTOR CODE 0x000 ; processor reset vector
goto main ; go to beginning of program
;call 0x3FF
; movlw 60h ; retrieve factory calibration value
; bsf STATUS,RP0 ; set file register bank to 1
;movwf OSCCAL ; update register with factory cal value
; 3460 @ 3F8
TIME EQU 42H
COUNT EQU 31H
COUNTA EQU 30H
COUNTB EQU 34H
; ======================== .25sec delay ===================================
DELAY1
MOVLW .25
MOVWF COUNT ; THIS SECTION PROVIDES A .25 SEC TIMMING PERIOD
TIMEA CLRF TMR0
LOOPC MOVF TMR0,W
SUBWF TIME,W
BTFSS STATUS,Z
GOTO LOOPC
DECFSZ COUNT
GOTO TIMEA
RETLW 0
; ======================= 1 SECOND DELAY =================================
DELAY
MOVLW .100
MOVWF COUNT ; THIS SECTION PROVIDES A 1 SEC TIMMING PERIOD
TIMEC CLRF TMR0
LOOPA MOVF TMR0,W
SUBWF TIME,W
BTFSS STATUS,Z
GOTO LOOPA
DECFSZ COUNT
GOTO TIMEC
RETLW 0
main
bsf STATUS,RP0 ; select bank 1
vrcon=0
movlw 60h ; retrieved factory calibration value
movwf OSCCAL ; put value into mem loc file reg address 90
CLRF ANSEL
movlw B'00000001' ; SET BIT 0 INPUTS GPIO 1>7 AS OUPUTS
movwf TRISIO ; SET BITS 2,3 AS INPUTS
movlw B'00000111'
movwf OPTION_REG
MOVLW .39
MOVWF TIME
bcf STATUS,RP0 ; select bank 0
CLRF GPIO
MOVLW 07H
MOVWF CMCON ;cmcon=7 ;turn off comparitor
CLRF ADCON0
clrwdt
clrf TMR0
;======================== BEGINING OF PROGRAM ============================
BEGIN
MOVLW .8
MOVWF COUNT
CHK BTFSC GPIO,0
GOTO CHK
;CALL DELAY1
BCF GPIO,1
CHK2 BTFSS GPIO,0
GOTO CHK2
;CALL DELAY1
DECFSZ COUNT
GOTO CHK
BSF GPIO,1
CALL DELAY1
BCF GPIO,1
GOTO BEGIN
END
;call 0x3FF
; 3460 @ 3F8
TIME EQU 42H
COUNT EQU 31H
COUNTA EQU 30H
COUNTB EQU 34H
DELAY1
MOVLW .25
TIMEA CLRF TMR0
LOOPC MOVF TMR0,W
SUBWF TIME,W
BTFSS STATUS,Z
GOTO LOOPC
DECFSZ COUNT
GOTO TIMEA
RETLW 0
DELAY
MOVLW .100
TIMEC CLRF TMR0
LOOPA MOVF TMR0,W
SUBWF TIME,W
BTFSS STATUS,Z
GOTO LOOPA
DECFSZ COUNT
GOTO TIMEC
RETLW 0
main
vrcon=0
CLRF ANSEL
movlw B'00000111'
movwf OPTION_REG
MOVLW .39
MOVWF TIME
CLRF GPIO
MOVLW 07H
CLRF ADCON0
clrwdt
clrf TMR0
BEGIN
MOVLW .8
MOVWF COUNT
CHK BTFSC GPIO,0
GOTO CHK
;CALL DELAY1
BCF GPIO,1
CHK2 BTFSS GPIO,0
GOTO CHK2
;CALL DELAY1
DECFSZ COUNT
GOTO CHK
BSF GPIO,1
CALL DELAY1
BCF GPIO,1
GOTO BEGIN
END
