Hi all,
Built a photodiode circuit (refer schematic Figure 1 - Link below) to
recieve pulses - square wave on "on" period 10us with varyin duty
cycles incident on the photodiode(BP104).
On testing the circuit, found the output at the trans-resistance
amplifier had some ringing at the edges (refer 2nd figure - 1st
response). The further the distance of the incident signal from the
transmitter, the more pronounced the ringing.
Tried to do some trouble shooting. Found the base of the transistor in
the gyrator circuit(R1, Q1, C1, R2) was not stable. Tried increasing C1
to 470nf to help fix this.. but still have the same problem,.
Also noticed C2 had a time constant associated with it.. with the same
response as at C1 (refer figure 3- 2nd response). So tried increasing
C2 to 1uf (non-polarised C), but still of no avail.
SO when the signal is near- clean square wave - can see C2 charging and
discharging. ( figure3)
As signal gets further - ringin at edges - response at C2 is almost a
flat line ( figure 2)
any ideas as to wot is causing this problem?
* please click on link for all figures and detailed explanantion:
http://generous.boy.googlepages.com/photodioderecievingcircuit
was unable to upload onto this page -sorry for the inconvenience
