Philips LCD TV 32MF605W/17: No Picture
Hello,
Have a Philips 32MF605W/17 LCD TV that will turn on, the backlits light
up for a second and you can see a picture than the backlites go off.
The TV remains on and you can hear the program.
Could this be a bad inverter? If some of the CCFL lamps are bad would
it shut all of them off?
Is there a way to test the inverter or the CCFL lamps?
Thanks,
Karl
W
webpa
Hello,
Thanks,
Karl
Most likely a bad inverter. Yes, that would shut ALL lamps off. You
are testing both inverter and lamps now: The inverter is bad.
K
Ken G.
It might be bad capacitor-s .. I have fixed a few LCD tv`s with only one
bad capacitor and the set was under 3 years old
David Naylor
Hello,
Thanks,
Karl
Yup Bad inverter but it is not usually sold seperatly, but sold with
the lcd display unit I work on these units every day for bb service
center Ref num 105 part # 823827718431 this is the lcd panel
assy inverter is not sold seperate
You David, you are correct. I have three in shop under warrantee that
have bad displays because the inverter BD's are bad. I work for Tower
TV in St. Paul MN.
To bad the inverts are not sold seperatly.
