Here's a Python program that does the calculations and reports the
results.
Mike, thanks for posting the code. I'm not familiar with Python but
it seems clear and readable enough.
Also, I want to thank you for the very useful information you have
posted on phase noise, and for the numerous links you have provided
in your various postings. In particular, the ones by Lee and
Hajimiri on Oscillator Phase Noise were very useful and I had not
come across them before. And, thank you for the very important prior
art info you found on the Binary Sampler - that was very helpful.
The reason I mention this is I find your posts valuable, and don't
want you to think I am attacking you in any way. I've been thinking
about the problem of how a seemingly reliable pll can suddenly
experience 100% failure, and have come to some conclusions that may
differ from yours.
First, the mode of failure is very strange. How can a simple pfd
work in different applications for years, then suddenly go bad?
It doesn't seem possible that it can be caused by one of the latches
resetting too quickly, leaving the other one still active. The set
and reset are one of the fastest circuits in D-flops, and the
minimum pulse widths are among the shortest listed in the datasheet.
Also, as Camenzind shows in Chapter 5, the first principle of linear
design is to rely on the close matching of parameters in
semiconductors. (Thanks for the url, Jim)
http://www.arraydesign.com/download/CHPTR5.PDF
This means both flops should have similar reset times. When the
feedback path includes the prop delay of an added gate, the
resulting reset pulse width seems more than sufficient to guarantee
that both flops or latches will be reset.
Recall this circuit has been used for decades and millions of parts
have been shipped without problem. So why should it suddenly show up
in your product? If there were problems in resetting the latches, it
should have been there from the beginning.
One indication of the true problem might be that your code doesn't
seem to account for the prop delay and risetimes of the current
sources. In fact, it appears your code can produce no result other
than a straight line, regardless of how much deadband is atually
present in the circuit!
Perhaps this kind of analysis really needs to be done in SPICE,
which can do a better job handling the transients involved. An
example is shown in Fig. 6 of Johansson's "A Simple Precharged CMOS
Phase Frequency Detector", IEEE Journal of Solid-State Circuits,
Vol. 33, No. 2, February 1998. (Please Note - I do not necessarily
agree with anything else he says, but the SPICE simulations are
very nice
http://iroi.seu.edu.cn/jssc9899/33ssc98/33ssc02/pdf/33ssc02-johansson2.pdf
So I think your code mislead you into believing that deadband was
impossible in your circuit. Also, from your response, it appears you
do not have a dedicated tester to view the response of the pll to a
variable pulse. Without this simple test, you have no way to look at
the response of the latches and charge pumps and see how much margin
actually exists before deadband shows up.
Now here's my hypothesis. You had a small amount of deadband in your
circuit from the beginning, but with your typical use, it never
showed up. Perhaps the normal system jitter was sufficient to mask
the deadband.
However, the new customer required a faster lock time, which means
increased loop bandwidth. Perhaps the system noise was also better,
which gave reduced system jitter. Under the new conditions, the loop
developed a limit cycle oscillation, which can grow to be quite
large.
This may have misled you into believing there was a problem
resetting the latches. So you installed Jim's DualD-PFD circuit and
the problem went away:
http://www.analog-innovations.com/SED/DualD-PFD.pdf
It is true his circuit works as you have described. It is also true
that it adds two prop delays to the reset path, which increases the
time that both current pumps are turned on in each cycle. If this
exceeds the risetime of the current pumps, the deadband disappears.
I am confident if you remove Jim's circuit and simply add an
equivalent delay in the reset path, you will obtain a similar
result.
Does this hypothesis sound reasonable and does it fit the available
information?
Best Wishes
Mike
