I m trying to create a PCB layout of IC AD9833 as mentioned in the datasheet.
I am using eagle software for the same.
AD9833 has a MSOP package with 10 pins.
I found the package in the library but the the line trace, grid is not adjustable to distinguish the adjacent pins. i mean to say that whenever i m trying to lay a track, the track goes to 1st , 3rd or 5th pin of that IC. it doesnot go to 2nd and 4th pin even if i set trace(width) to lowest.
