Spehro,
Do you want a slot or a figure eight shape?
I always use one of either two methods for such things.
1) I use a unique hole size for one pad, 1 - 5mils, something
they cannot attempt to drill. Then do a note referencing that
drill size and a small drawing outlining the shape and dimensions
based upon the unique hole size being the center of one of your
lobes.
2) If it is a slot, then I usually use a mechanical layer to
draw the shape I want in the correct location and orientation.
Then reference it in your notes telling the fabricator that this
shape is desired and that it is plated. Make sure there is some
common reference between layers so that a Gerber set aligns the
detail precisely where you want it and in the correct orientation
on the PCB.
I have also give these details on multiple layers with the
lines actually including an offset for appropriate router bit
diameters that I know the fabricator has. Theses layers are then
just a router centerline path for them to program into their
machine.
Sincerely,
Brad Velander
Spehro Pefhany said:
Is this generally acceptable? I want to overlap two of 0.136" holes by
about 0.024" in several places. They are plated with no electrical
function.
Thanks!
Best regards,
Spehro Pefhany
http://www.speff.com
