H
hartman1
can anyone recomend what I should do to fix the following,
I have designed a pcb which uses 12-16VAC input and have a common ground
connected on the neg side of power diodes, my panel has failed 1000vac
dielectrical test between ground and ac connector. Im told this is
because i connected directly on other side of diodes, how can I fix this??
