Jeffery Tomas
I have a device that, by itself, does not infringe a patent, but does when
the user uses it, it is still patent infringement?
That is, by itself, it doesn't violate all the claims when made and in fact
doesn't even have to be like the device in the patent, but can be(and is
intended) to be used like the device in the patent.
Here is very simple example
Patent Claims
1. A device that is square
2. Said device in claim 1 has a round dot on it.
My device is square but no round dot on it. I intend the user to put the
round dot on it for similar reasons in the patent so the device will be used
the right way but they don't have to and it will still function. My device
is not exactly like the patent device but very close.
The problem is, that the patented device uses some very general language and
some things that are simply almost necessary. For example. Claim: The square
is made out of wood. Well, there really is no other option. It can't be made
out of metal, moth balls, cotton candy, etc... There are only 2 things that
it can be made out of that will at all make it useful and the patent gets
them both. It would be possible to make it out of the other things to get
around the patent but then the device wouldn't be useful. Just take my word
on it.
Another example is claim 2. It is necessary for the dot because without the
dot the device can't function in any useful way. (just take it for
granted... this is just a silly example)
It would be like patenting a bolt and the dots being analogous to the
threads.. although at least that has a bit more alternatives. In my case
there is no other way since either you put the dot on and the device works
or you don't and it doesn't.
I know the example is silly but if it take it only in the context I've given
and don't try to add anything extra and think about the logic itself it
shouldn't be too hard to answer.
My guess is if I created my device and sold it I would get sued either
way(since my device is better). Even though I created my device without any
knowledge of the other and, while it is different it is also similar(but
similar because there are very few ways to do it in the first place... and
any engineer given the criteria would come up with a similar device). My
device is better as it provides more utility but, again, had to follow
certain fundamental engineering properties because it is the nature of the
problem.
In the patent one of the claims is the thickness of the square and they say
"Approximately 0.0001 in to 1.5 in" but if the device was even anywhere
greater than 0.2 in it would be useless(too thick for the user).
The patent branches out a bit and covers many different variations of the
device. It basically prevents any variations. Of course they did this to
prevent competition. Unfortunately I've created a device, already have it
done, that improves on the concept(again though, I didn't steal the idea
because I didn't know about it until I started research the patents). Seems
like my device may never see the light of day though. My only thought is
that I could sale the device without the dot and let the user add the dot to
it... even if that was possible it wouldn't be very viable as it is a bit
difficult to add the dot(the average user would have to take it to a tech).
In the original patent they talk about assemblies an patent all the parts of
the assembly(although each part except what I have come up with is has been
around for centuries). They created their device, to be built as one while I
created mine to be easily inserted into the already existing assemblies.
Mine was about economy while theirs is not.
What gets me is that just about any engineer could come up with basically
the same things if given just a few requirements and goals. The patent
though prevents all these ideas by basically patenting how the device is to
be used in another device(that isn't patented but is required to make the
new device useful).
Another simple silly analogy is patenting a battery by patenting the devices
that will use it and using general enough language to get all the devices
that will use it. If you could do that you could prevent any other similar
batteries, from being used. In my case the main device(the thing actually
created) consists of just a simple circuit board with a few common ic's with
very basic function(like just simple sensors and a ic to read them).
Patent Claims
on it.
problem.
new device useful).
