j r powell
I have a small stereo amplifier which came with two tiny 4ohm 3watt speakers.
I'd like to combine the two channels of the amp in order to drive one, slightly
larger, 8ohm 4watt speaker.
The amp is of the non-bridgeable type, so I assume parallel wiring would be
required - combining the two outputs together. I have read that small resistors
are required in parallel configuration, to enable proper current sharing between
the amplifiers, as without them the two amps would fight each other and
overheat. Can anyone tell me the correct values for these resistors, and where
they should be placed?
thanks,
jamie.
thanks,
jamie.
