Parallel LRC circuit analysis help
Hello I have a parallel RLC circuit and I am struggling to find the following parameters:
1) Total Circuit current
2) phase angle relative to the supply
3) Total Circuit Impedance using j operation (complex notation)
4) Power dissipated in the resistor
Link to Circuit diagram:
http://i695.photobucket.com/albums/vv313/patel5557600/kjadsbcksjdb_zps4027ce59.png
II have also attached a simple circuit diagram in this thread
My workings so far:
V=12V peak= 12/√2=8.49 V_RMS
f=10KHz
R=10Ω
L=150μH
C=330nF
1 - Circuit Current
I_R=V/R=8.49/10=0.849A
I_L=V/X_L =8.49/9.42=0.901A
I_C=V/X_L =8.49/48.23=0.176A
I= √(〖I_R〗^2+(I_L - I_C )^2 )
I= √(〖0.849〗^2+(0.901-0.176)^2 )
I= 1.116A
2 - Phase Angle
〖G=〗⁡〖1/R〗
〖G=〗⁡〖1/10〗
〖G=〗⁡〖0.1 s〗
〖θ=tan〗^(-1)⁡〖G/Y〗
〖θ=tan〗^(-1)⁡〖0.1/0.132〗
θ=⁡〖37.15〗
3 - Impedance Using J operator
1/Z=√((1/R)^2+(1/X_L -1/X_C )^2 )
1/Z=√((1/j10)^2+(1/(-j9.42)-1/j48.23)^2 )
1/Z=√(((1∠0)/(10∠90))^2+((1∠0)/(9.42∠-9... )
Y=1/Z=√((0.1∠-90)^2+((0.106∠-90)-(0.020... )
4 - Power Dissipated
P=VIcosϑ
P=(8.49)(1.116)cos⁡(37.15)
P=7.56W
Can someone please confirm these results? If I have gone wrong, could someone please correct me. Any help would be much appreciated.
Thank you
This is partly beyond me but 4. is wrong.
There is 8.49V rms across the 10R resistor. The other compnents do not come into it since they do not dissipate power.
Also in 1. Ic is given as a function of Xl. I presume this is a typo.
Look very good. Only thing I can see that might be wrong is you state R as being j10 as being an imaginary number. Shouldn't it be just 1/10. The average power in the coil and capacitor if ideal components will be zero. The phase angles are +90 and -90 for ideal inductor and capacitor that being the voltage and current. The resistor does not have a phase.
Adam
