MHZ go back and catch my add on . . . . . . to my POST # 17.
Sir 73's de Edd,
Strange, because I had exactly same one before, and always worked fine
I don't know what's wrong now... Especially that this one is new out of the box ???
Most certainly should not.I checked that add, and it might have to do with NEW networking technology and an older phone etc...
Garbage. I see where the logic is, but this is not the case.About "Out of range errors" people get with this phone
ByTim G. Corcoranon January 3, 2003
Color: Black
It's funny how many reviews on here say these phones worked for awhile but eventually would transmit but not receive, give out of range errors etc. This is NOT STRICTLY the phones fault people...
The problem is so many 801.11b WiFi networks in use today and that technology uses the same 2.4GHz band this phone uses for receiving from the base... so the phone gets "static" and can't work. The 900MHz band it uses for transmitting to the base is unaffected, get it?
So the problem is the new networking technology and an older phone... Fault Panasonic for not having a better design that could handle this interference maybe, but your phone isn't broken... I really love this phone and am sorry to have to get another.
You can do what I did, try a 5.8GHz phone, it'll be fine until someone uses that band too for a computer network![]()
Megglinghurts:
See if these two little tid - bits of info on your unit help you . . . . . .:
http://www.manualslib.com/manual/303866/Panasonic-Kx-Tg2570.html?page=50#manual
http://www.manualslib.com/manual/303866/Panasonic-Kx-Tg2570.html?page=65#manual
73's de Edd
Do you live in an apartment or town-house complex with lots of other people?Actually the old phone didn't break (for as far as I know). It gave the same error, and that's why I thought I'd try the new one. But, both phones (OLD & NEW) are IDENTICAL !
Could it be the battery ? However, I fully charged it, and it remains charged
If so, you can try a new battery... but I doubt it will remedy the situation.
When did the old phone stop working?
The WiFi networks mentioned above are not supposed to put out a bunch of interference on other channels, but they do... and the cheap or ill-designed WiFi devices can cause excessive noise. If this is noise related, turn off or unplug the WiFi or other devices on the wireless network and see if you can get your phone to work.
This won't be possible if you are living in a high density building though with lots of other tenants/owners
