K
Kevin Aylward
Ken said:[.. I wrote ..]Followed by a comment where I explain that two way communication isNo, this is just another case where the cat is both fed and unfed[1]
until you check on it.
needed before you have proven FTL communications.
Ho hum. No it aint.
http://www.anasoft.co.uk/quantummechanics/index.html
"Shrodingers Cat was introduced to prove that the standard Copenhagen
Interpretation of Quantum Mechanics was false. It achieved this, yet
many simply failed to notice."
Your web site states:
The Ensemble Interpretation does not attempt any explanation as to why
Quantum Mechanics is the way it is. It simply states the most
rational way of interpreting and calculating the results without
introducing the blatant contradictions that are indeed in the
Copenhagen interpretation, in addition to removing all excess
metaphysical baggage.
So it isn't really talking about what the true state of affairs for
Shrodinger's cat is.
It says that there is no *actual* combined state, i.e. no *real*
simultaneous dead and alive state. That is, |phy> = |a> + |b> is
mathematical *notation*. As was noted, throwing *classical* dice can be
formulated with the *same* notation, where upon it is clear that there
is no suggestion that a dice can exist in more than one state at once.
The equation only has meaning in calculating results from ensembles of
measurements. The equation is not a statement about an individual
object.
The point is, is that the ensemble interpretation, agrees with all
experimental results, and doesn't require a real physical combined
state. If we don't need an idea, that on its face is daft, why hold on
it it?
Kevin Aylward
[email protected]
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
