Output voltage regulation help me
Hi to all
If smps power supply output voltage is 50v, shall we decrease any voltage (for instance 25 or 15v) with feedback control.
If So , what happens in circuit
Will power supply work fine or not ?
Thanks in advance
What exactly do you want to achieve?
Set up the 50 V power supply for a lower output voltage? Or add a second regulator after the 50 V output to get a second, lower output voltage?
If So , what happens in circuit?
Depends very much on the circuit. There are many different power supply designs, not just one.
Thanks . But I say :
Only one output 50v 3a
Input voltage 140-150v
Efficiency 80%
Transformer wingding
Np:40t
Ns:19t
No auxiliary windings
Pwm:tl494
Operation half bridge
If output is 50v,can i make adjustable voltage from 3v from 50v with FEEDBACK control
Work I made
I put potentiometer to pin 1 of tl494 for adjustable output from 4v till 50v
But this feedback is right way or not?
Transformer Ns is for 50 v
But decreasing duty cycle via feedback control, regulating output voltage is right way?
From 19 turns of sencondary to lower voltage is right way decreasing duty cycle via feedback control?
I don't need other circuits
Thansk in advance
We will neeed a complete schematic to help you. The information we have so far is insufficient, sorry.
