Hi wizards! Me again. With another power supply problem. I've been very quiet for a while because of the pandemic but I recently started tinkering again so here's my new problem. I have two identical power supplies that have two different problems. The power supplies are 90~130VAC input and two DC outputs, one 390VDC to an HID lamp ballast and one 24VDC to drive other electronics. These power supplies are very old but, having nothing but time on my hands, I decided to change out all the main components (fast recovery diode, MOSFETS etc.) These units were dead before but after changing out these components, they sprung back to life. HOWEVER, I'm getting a low reading on the 390VDC side, fluctuating around 345~355VDC (the 24VDC leg is fine there, no fluctuations). I'm wondering if the fluctuations would be caused by the main capacitor (450V 100mf) being weak. I pulled the cap in question and tested it and it read around 90mf which I think is a little low. Would this cap cause the fluctuating low voltage? I'd be grateful for any advice which will help me to add to my limited knowledge base.
Platforms
Content
