Help! With troubleshooting SMPS for a Denon reciver. (Low output voltage)
I'm trying to fix a power supply for a denon reciver, AVRX2100W, but now I'm stuck.
At first, the AC/DC converter (MAG258MG) had blown, so I replace that along with some diode's, see attached picture.
When measuring the output voltage I get 1V, and it should be 5.2V.
Any ideas on what could be the cause on the voltage drop? Thanks!
I'm no expert when it comes to this sort of stuff (read noob), but from what I understand, the optocoupler is supposed to regulate the amount of voltage that the SMPS puts out. If it's reading wrong it could throttle the output. Something like a bad zener mentioned above could certainly cause it
