JoeBloe
Start with new (6-month old), bleeding edge stuff: motherboard, Intel
D CPU, 80Gbyte hard drive, Sony DVD R/W, 500W supply, WinXP Pro.
Major problems:
1) "Intel uCode error...press F1 to continue" no boot from the WinXP CD.
2) Update BIOS to latest available (beta): the uCode error goes away; no
boot.
3) Go into the BIOS setup, first screen: *nothing* recognized; Primary
Master, Primary Slave,Seconsdary Master and Secondary Slave all have the
same message, to the effect "nothing available".
Sounds like a failed BIOS upgrade FLASH burn.
I only get ASUS Mobos. Flashable from a boot CD.
What is yours?
But, in booting up, there is a bit of screen fiddling,
Worrisome. Did you go back into your BIOS settings after the FLASH
and set things up again (not just HD recognition)?
and the
installed hard drive and DVD drive are listed as present.
Interesting. Almost sounds like it has an IRQ conflict on the PCI
PNP bus that it is having trouble arbitrating.
Could also be a MOBO setting for looking at PCI first, before AGP or
PCIx.
The DVD light has a very short blink after that, but the CD is not
accessed.
That may be your master/slave setups. You know the master hard
drive goes on the end of the IDE cable, right? Especially for UDMA.
If you are SATA disregard.
Now, the interesting part: plop in a PartitionMagic (bootable) CD,
and that works!
It should.
Understand, the PartitionMagic CD is old, way before Micro$uck
thought of XP (2002).
So. Try a Knoppix Live CD. It auto-recognizes EVERYTHING
(virtually).
Seems to me that M$ has teamed with the BIOS and board makers to make
sure that one cannot *install* WinXp from scratch on these new computers.
Nope. It may be the Intel CPU ID thing.
But..if you happen to have a computer like that with WinXP installed,
the WinXP is readable and can be used for updates, etc.
So.
So....
How in the h*ll does one start from scratch?
If you have Win XP update, you have to have an OS on the drive to
update it.
If you have the full (fool version j/k) version, you should be
able to install from it. It should state "Press any key to boot from
CD" as the BIOS POST routine finishes, and it hits the disc.
